[GRASSLIST:3588] Re: Linux startx problem
Eric G. Miller egm2 at jps.net
Thu Apr 25 23:51:12 EDT 2002
On Thu, Apr 25, 2002 at 11:55:37PM -0400, Kirk Schmidt wrote:
>  Good Morning:
> I have run into a Linux based snag that has stopped me cold.
> I am running RH Linux 6.2 and I was ready to start up a Grass session
> when I activated startx
> the following message appeared after the process crashed:
> Font Tran Socket Unix Connect: Can't connect: Errno = 111
> failed to set default font path 'unix/:-1'
> Fatal server error
> could not open default font
> I ran into a hardrive error and had to use fsck to fix up the drive.  I
> assume I lost a connection to the font files startx is looking for.
> I assume I will have to reinstall some portion of the original OS.
> Any suggestions on how to proceed would be greatly appreciated
Ask on a list that discusses Redhat or Linux.  Your problem has zero
connection to GRASS.  You probably haven't configured X...
Eric G. Miller <egm2 at jps.net>
