[GRASSLIST:3587] Linux startx problem
Kirk Schmidt kirkschmidt at auracom.com
Thu Apr 25 23:55:37 EDT 2002
  Good Morning:
I have run into a Linux based snag that has stopped me cold.
I am running RH Linux 6.2 and I was ready to start up a Grass session
when I activated startx
the following message appeared after the process crashed:
Font Tran Socket Unix Connect: Can't connect: Errno = 111
failed to set default font path 'unix/:-1'
Fatal server error
could not open default font
I ran into a hardrive error and had to use fsck to fix up the drive.  I
assume I lost a connection to the font files startx is looking for.
I assume I will have to reinstall some portion of the original OS.
Any suggestions on how to proceed would be greatly appreciated
Kirk Schmidt
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
tel 902.922-3609
fax 902.922.3607
Thorburn
