[GRASSLIST:3589] Re: Linux startx problem
ivan
ivan at es.usyd.edu.au
Fri Apr 26 00:48:55 EDT 2002
On Thu, 25 Apr 2002, Kirk Schmidt wrote:
Try to comment out this line in /etc/X11/XF86Config by putting "#" at the
beginning of the line, then restart X "startx".
> Good Morning:
> I have run into a Linux based snag that has stopped me cold.
> I am running RH Linux 6.2 and I was ready to start up a Grass session
> when I activated startx
> the following message appeared after the process crashed:
> Font Tran Socket Unix Connect: Can't connect: Errno = 111
> failed to set default font path 'unix/:-1'
> Fatal server error
> could not open default font
> I ran into a hardrive error and had to use fsck to fix up the drive. I
> assume I lost a connection to the font files startx is looking for.
> I assume I will have to reinstall some portion of the original OS.
> Any suggestions on how to proceed would be greatly appreciated
> Kirk Schmidt
> Nortek Resource Solutions Inc.
> RR # 1
> Thorburn, NS
> B0K 1W0
> tel 902.922-3609
> fax 902.922.3607
> Thorburn
There's an old story about the person who wished his computer were as
easy to use as his telephone. That wish has come true, since I no
longer know how to use my telephone.
Ivan Teliatnikov,
F05 David Edgeworth Building,
Department of Geology and Geophysics,
School of Geosciences,
University of Sydney, 2006
Australia
e-mail: ivan at es.usyd.edu.au
ph: 061-2-9351-2031 (w)
fax: 061-2-9351-0184 (w)
