[GRASSLIST:3599] Re: problems with grass 5.0.0pre3
rgrmill at rt66.com
rgrmill at rt66.com
Fri Apr 26 14:54:07 EDT 2002
Andriy wrote:
> I am using Red Hat 7.2 and I have recently installed
> the newest version ofgrass (5.0.0.pre3). The problem I have
encountered is
> how to reclass NODATA in raster files into numerical values that
could
> be used to perform someuseful calculations. The problem is that I
cannot use
> any mathematicaloperations when NO DATA is present and I cannot
manage
> to reclass that. Itried r.reclass but it did not help.
You can use r.mapcalc to change the NODATA (or NULL) value to something
else. The form would be something like
r.mapcalc "output=if(isnull(input),new_value,input)"
in which input and output would be replaced with the names of you input
and output raster files, respectively and new_value would be some
integer that you want to replace the NODATA values. The quotation marks
in this example are required.
If your map is of type CELL then you should be able to reclass your
output map with r.reclass. Instances where you need to do this
replacement should be rare. If you truly have no data then you really
can't do very much that is useful.
> The other problem occurs when I am importing dxf and
> tiff file formats. Thewhole map contains only NO DATA (tiff) or 0
(dxf). I
> ran v.support andg.region, the map displayed correctly but was
useless
> for any furtheranalysis. I couldn't reclass that dxf either.
TIFF and DXF formats are handled through completely different import
tools and result in completely different types of files; TIFF files
import to raster files and DXF files import to vector files. You would
not run v.support on an imported TIFF file.
You don't provide much basis for me to give you help, so these
suggestions are generic.
Use r.in.gdal to import the TIFF file. If the file is not georeferenced
(a tiff world file) then you will probably want to georeference the
raster file after it is imported. You can georeference the raster file
either by editing the header with r.support or by registering it with
i.rectify. There may be other tools as well.
Use v.in.dxf to import the DXF file. v.in.dxf is fairly robust, but it
does not handle all types of dxf objects. Keep in mind that DXF files
are often not in geographic coordinates. If that is true in your case
then you may be able to use v.transform to supply the necessary
coordinates. You should be able to view the imported file in a GRASS
monitor without first running v.support, but that is about all you can
do with the file.
The GRASS monitor displays data within pre-set coordinates. If the
coordinates of your imported file are not within those pre-set
coordinates then you will need to adjust the screen coordinates before
you can view the file. Do that with g.region rast=<raster map name> or
g.region vect=<vector map name>.
Good luck,
Roger Miller
