[GRASSLIST:3601] Re: legend and ps.map
rgrmill at rt66.com
rgrmill at rt66.com
Fri Apr 26 15:52:12 EDT 2002
Henning Ries wrote:
> Dear GRASS users,
> is there any way to use a floating point legend (flowaccumulation)
with
> ps.map?
> I also tried p.map.new to print floating point maps with a proper
legend.
> Unfortunately p.map suffers a memory access failure while gathering
map
> statistics.
> I am using 5pre3 on SuSE7.3.
I'm sorry that I can't help with your problem. Regarding the memory
access failure, would you please file a bug report at
http://grass.itc.it/bugtracking/bugreport.html
Please offer as much detail as you can. It's the only way that problems
actually get fixed.
Roger Miller
