[GRASSLIST:4191] Re: repair unclosed vector areas?
andres javier garcia garcia andresjavier.garcia at wanadoo.es
Thu Aug 1 14:35:57 EDT 2002
Altough I guess there are better methods, I import vector files as ASCIII,
and modify the ASCII, vector files by hand, repeating for each area, the
first point of the polygon at the of the points for the area. Then I use:
v.in.ascii
This works, but maybe there is some tool to repair it automatically.
Javier García
Department of Soil and Water Conservation
CEBAS-CSIC
Apartado 4195 30080 Murcia (España)
Phone: 34-968396257
> Dear List,
> I imported vector data with v.in.arc and v.support
> gives a hundred unclosed areas.
> Unclosed area, free end or edge inside area: line 3
> Unclosed area, free end or edge inside area: line 19
> Unclosed area, free end or edge inside area: line 27
> Unclosed area, free end or edge inside area: line 28
> Unclosed area, free end or edge inside area: line 325
> Unclosed area, free end or edge inside area: line 326
> Unclosed area, free end or edge inside area: line 328
> Can I fix this somehow? Is there a common way to deal
> with this problem?
> thanks
>   Otto
