[GRASSLIST:4200] Re: d.what.v.pg problem
    Glynn Clements
    glynn.clements at virgin.net
    Fri Aug  2 11:03:44 EDT 2002
orkun wrote:
> when U use this command
> (d.what.v.pg -f map=f28mr tab=koy col='no' color=white fillcolor=blue)
> I get "No socket to connect to for monitor <x1>.
> ERROR eof from graphics driver." message
> Same problem occurs d.vect.pg key=no tab=koy where=12 map=f28mr color=indigo
> I checked postgresql. Nothing seems to wrong.
> What might lead the problem ?
The active monitor is "x1", but it isn't running. If no monitors are
running, use "d.mon start=x0" to start one. If "x0" is already
running, use "d.mon select=x0" to make it the active monitor.
Glynn Clements <glynn.clements at virgin.net>
