[GRASSLIST:4214] Re: d.what.v.pg problem
Glynn Clements
glynn.clements at virgin.net
Mon Aug 5 06:02:52 EDT 2002
orkun wrote:
> > > when U use this command
> > > (d.what.v.pg -f map=f28mr tab=koy col='no' color=white fillcolor=blue)
> > > I get "No socket to connect to for monitor <x1>.
> > > ERROR eof from graphics driver." message
> > > Same problem occurs d.vect.pg key=no tab=koy where=12 map=f28mr color=indigo
> > > I checked postgresql. Nothing seems to wrong.
> > > What might lead the problem ?
> > The active monitor is "x1", but it isn't running. If no monitors are
> > running, use "d.mon start=x0" to start one. If "x0" is already
> > running, use "d.mon select=x0" to make it the active monitor.
> The problem still goes on
> Here is my command sequence
> GRASS:~ > d.mon start=x0
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> GRASS:~ > d.vect map=f28mr color=green
> GRASS:~ > g.select.pg database=dbbk1
> GRASS:~ > d.what.v.pg map=f28mr tab=koy col=no color=green
> No socket to connect to for monitor <x0>.
So, d.vect works, but d.what.v.pg doesn't?
In that case, my suspicion is that d.what.v.pg is from an old version
of GRASS, and isn't compatible with the monitor driver.
Glynn Clements <glynn.clements at virgin.net>
