[GRASSLIST:4232] Re: Importing Vectors
Gordon Keith
gordon.keith at csiro.au
Tue Aug 6 23:56:25 EDT 2002
On Tue, 6 Aug 2002 22:09, Markus Neteler wrote:
> Hi,
> maybe a workaround: Try to use "ogr2ogr" (part of GDAL):
> http://www.remotesensing.org/gdal/
> It allows for conversion of MapInfo to SHAPE:
> ogr2ogr -f "ESRI Shapefile" out.shp in.mif
> Then
> v.in.shape out.shp ...
It gave the following:
File `training.shp' is of Type Area (Polygon) with 92 entries.
Bounds:
W: 130.611056, E: 150.269383, S: -38.254678, N:
-31.828629.
ERROR: Polygon controller contained error.
FATAL ERROR: There was a problem importing the map.
but I found the problem with v.in.ascii, I can't spell.
> > The file has the following header:
> > ORGANIZAITON:
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
The main thing is keep the main thing the main thing.
