[GRASSLIST:4276] Re: "Draping" vectors on raster maps
    Ben Logan
    ben at wblogan.net
    Sun Aug 11 18:29:02 EDT 2002
On Sun, Aug 11, 2002 at 02:03:32PM +0200, Andrew Wade wrote:
> Hi all
> I'm trying to do something in grass I haven't had to before - taking a
> vector map (a vehicle's route incidentally) and draping it over the
> topography of the area to show more visually where the vehicle
> travelled.  What would I use to do this?
I believe that nviz is the tool you are looking for.  You can plot a
3D view of the topography, and then drape the vector map of the roads
over that.  To play around, try something like
GRASS: ~> nviz elev
(replace 'elev' with the name of your elevation map).
> Also, what is the command to make animations along a path
> again?
This can also be done from within nviz.  Take a look at
$GISBASE/documents/nviz/nviz_tut.html (from within Grass--the path is
correct for my installation of Grass 5pre4) for a tutorial on nviz.
HTH,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
Washington, D.C: Fifty square miles almost completely surrounded by reality.
