[GRASSLIST:4333] gislock problem - revisited
Jack Varga
jvarga at boulder.net
Tue Aug 20 01:00:18 EDT 2002
I too am having this problem with pre5, and followed Markus'
suggestion but to no avail. Any help appreciated.
`gmake5 -i src/general/init/` produces the following output...
$ gmake5 -i src/general/init/
SRC = /home/jvarga/tmp/grass5.0.0pre5/src
CMD = /home/jvarga/tmp/grass5.0.0pre5/src/CMD
UNUSED = /home/jvarga/tmp/grass5.0.0pre5/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/jvarga/tmp/grass5.0.0pre5/dist.i686-pc-linux-gnu
VERSION = 5.0.0pre5 June 2002
/home/jvarga/tmp/grass5.0.0pre5/src/general/init
make -f OBJ.i686-pc-linux-gnu/make.rules
rm -f /home/jvarga/tmp/grass5.0.0pre5/bin.i686-pc-linux-gnu/grass`cat
/home/jvar
ga/tmp/grass5.0.0pre5/src/CMD/VERSION | head -1 | sed 's/\..*//'` ; true
/bin/sh -c "sed -e
\"s#GISBASE_VALUE#/home/jvarga/tmp/grass5.0.0pre5/dist.i686-p
c-linux-gnu#\" -e \"s#PERL_COMMAND#/usr/bin/perl#\" grass.src >
/home/jvarga/tmp
src/CMD/VERSION | head -1 | sed 's/\..*//'` 2>/dev/null ; true"
chmod a+x
/home/jvarga/tmp/grass5.0.0pre5/bin.i686-pc-linux-gnu/grass`cat /home/
jvarga/tmp/grass5.0.0pre5/src/CMD/VERSION | head -1 | sed 's/\..*//'`
make: *** No rule to make target
`/home/jvarga/tmp/grass5.0.0pre5/src/libes/LIB.
i686-pc-linux-gnu/libedit.a', needed by
`/home/jvarga/tmp/grass5.0.0pre5/dist.i6
86-pc-linux-gnu/etc/set_data'. Stop.
From grasslist archive...
On Jun 05, 2002, Markus Neteler wrote:
>it seems that the program
>/usr/local/grass5/etc/lock
>is missing.
>Try to recompile
>and check if 'lock' is compiled.
>Good luck,
> Markus
>>Can't properly access /home/wouter/.gislock5
>>please notify system personel
>>However as root (su) I can start up grass
>>Changing back to normal user (su wouter) also works
>>Someaone who nows how to solve?
>>Thanks!
>>Wouter
