[GRASSLIST:4334] Re: gislock problem - revisited
Eric G. Miller
egm2 at jps.net
Tue Aug 20 01:14:50 EDT 2002
On Mon, Aug 19, 2002 at 11:00:18PM -0600, Jack Varga wrote:
> I too am having this problem with pre5, and followed Markus'
> suggestion but to no avail. Any help appreciated.
> `gmake5 -i src/general/init/` produces the following output...
> $ gmake5 -i src/general/init/
> SRC = /home/jvarga/tmp/grass5.0.0pre5/src
> CMD = /home/jvarga/tmp/grass5.0.0pre5/src/CMD
> UNUSED = /home/jvarga/tmp/grass5.0.0pre5/unused
> HEADER = head.i686-pc-linux-gnu
> ARCH = i686-pc-linux-gnu
> GISBASE = /home/jvarga/tmp/grass5.0.0pre5/dist.i686-pc-linux-gnu
> VERSION = 5.0.0pre5 June 2002
> /home/jvarga/tmp/grass5.0.0pre5/src/general/init
> make -f OBJ.i686-pc-linux-gnu/make.rules
> rm -f /home/jvarga/tmp/grass5.0.0pre5/bin.i686-pc-linux-gnu/grass`cat
> /home/jvar
> ga/tmp/grass5.0.0pre5/src/CMD/VERSION | head -1 | sed 's/\..*//'` ; true
> /bin/sh -c "sed -e
> \"s#GISBASE_VALUE#/home/jvarga/tmp/grass5.0.0pre5/dist.i686-p
> c-linux-gnu#\" -e \"s#PERL_COMMAND#/usr/bin/perl#\" grass.src >
> /home/jvarga/tmp
> src/CMD/VERSION | head -1 | sed 's/\..*//'` 2>/dev/null ; true"
> chmod a+x
> /home/jvarga/tmp/grass5.0.0pre5/bin.i686-pc-linux-gnu/grass`cat /home/
> jvarga/tmp/grass5.0.0pre5/src/CMD/VERSION | head -1 | sed 's/\..*//'`
> make: *** No rule to make target
> `/home/jvarga/tmp/grass5.0.0pre5/src/libes/LIB.
> i686-pc-linux-gnu/libedit.a', needed by
Looks like the libedit.a compilation bug with gcc-2.96. See archives
for src/libes/edit/edit_cellhd.c fix, or grab CVS version which has
the fix.
Eric G. Miller <egm2 at jps.net>
