[GRASSLIST:4398] Re: d.dm error
Henning Ries henning-r at web.de
Wed Aug 28 14:35:36 EDT 2002
Hi Radim
Am Mittwoch, 28. August 2002 16:59 schrieben Sie:
> You may have other version of BWidget installed on your system. I know that
> SelectColor was changed in new versions and it is not backward compatible.
> I am not sure in which order are packages loaded. Could you try to replace
> in d.dm row:
> package require BWidget
> by
> package require -exact BWidget 1.2.1
That solves the problem.
Thank you
Henning
