[GRASSLIST:5124] Re: Labeling imported layers
douggorley at shaw.ca
Sun Dec 1 22:09:48 EST 2002
I have access to Arc/Info with the source data. Is there a better way to export the data so that I don't have to relabel everything?
Doug Gorley | douggorley at shaw.ca
----- Original Message -----
Date: Sunday, December 1, 2002 7:01 pm
Subject: [GRASSLIST:5123] Re: Labeling imported layers
> On Sun, Dec 01, 2002 at 06:42:07PM -0800, douggorley at shaw.ca wrote:
> > I'm using some data I imported from Arc/Info using Arc's
> > "ungenerate"command. It doesn't appear to have any categories in
> the> imported layer. All I need is to assign a single category to
> all of
> > the lines in my layer, so I can do some buffering. I'm trying to do
> > this with v.digit, using the "B - Bulk Label Remaining Lines"
> option,> but I'm not having any success. Is this the correct way
> to do what I
> > want, and if not, can someone give me some advice on what to do?
> Yes, AFAIK "ungenerate" data just give you geometry.
> See, v.llabel for a bulk line labelling.
> "...the plural of anecdote is [not?] data." - attrib. to George
> Stigler
