[GRASSLIST:5123] Re: Labeling imported layers
Eric G. Miller
egm2 at jps.net
Sun Dec 1 22:01:06 EST 2002
On Sun, Dec 01, 2002 at 06:42:07PM -0800, douggorley at shaw.ca wrote:
> I'm using some data I imported from Arc/Info using Arc's
> "ungenerate"command. It doesn't appear to have any categories in the
> imported layer. All I need is to assign a single category to all of
> the lines in my layer, so I can do some buffering. I'm trying to do
> this with v.digit, using the "B - Bulk Label Remaining Lines" option,
> but I'm not having any success. Is this the correct way to do what I
> want, and if not, can someone give me some advice on what to do?
Yes, AFAIK "ungenerate" data just give you geometry.
See, v.llabel for a bulk line labelling.
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
