[GRASSLIST:5127] Re: Labeling imported layers
Eric G. Miller
egm2 at jps.net
Sun Dec 1 23:03:37 EST 2002
On Sun, Dec 01, 2002 at 07:40:22PM -0800, douggorley at shaw.ca wrote:
> Excellent; now I have categories on all my lines. I thought the way
> to "flatten" this so that all of the lines are of the same class would
> be to use v.reclass, but I keep getting the message, "WARNING:
> category support for vector file [lakes] in mapset [doug] missing".
> Do you know what I can do to fix that?
Well, there're two files for "category support". One is dig_att/<name>
and the other is dig_cats/<name>. If you used m.in.e00, it creates
several dig_cats/ files with names like <name>.<field>. Use symbolic
links to make a dig_cats/<name> file point to the attribute file of
"choice".
Also, you did run v.support?
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
