[GRASSLIST:5165] libncurses
Stephanie Granger
steph at derecho.jpl.nasa.gov
Thu Dec 5 19:50:48 EST 2002
Hello,
I am using grass on my pc with no problems, but I am having trouble
getting grass 5.0.0 running on my Unix system (sparc-sun-solaris2.8)
and need help/hints.
I downloaded the tar file, unzipped it, configured, built and
installed grass-5.0.0 without error. When I try to run it using
the command grass5 or grass5 -tcltk I get the following error message:
ld.so.1: set_data: fatal: libncurses.so.5: open failed: No such file or
directory
I do have libncurses.so.5 and included the path for the includes
and the libs when I configured the system. I'm not sure what I'm
missing. I would appreciate any help that the list can offer. Also,
the error logs showed no errors in the build or install.
Oh, I do not have root access and installed the software in my own area
rather than /usr/local/grass5.
Thanks in advance,
Stephanie Granger
Stephanie Granger Stephanie.Granger at jpl.nasa.gov
Jet Propulsion Laboratory
Mail Stop 169-237
4800 Oak Grove Dr. Voice (818) 354-5683
Pasadena, CA 91109 FAX (818) 393-4619
