[GRASSLIST:5198] Extracting line data & poitn data form a file.
Antonio G. - Geotronix nightnavigator at libero.it
Mon Dec 9 15:34:14 EST 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi.
I have a vect file in which I have both point data (elevation points,
mountain peaks & so on) and line data (equal elevation lines of
topografic map). I would like to separate the two types of data so as to
generate two diffrent files, one holding the point data and the other
the line data. This is because having them in the same file makes a lot
of confusion while having them in two diffrent file make things a bit
clearer.
Thanks in advance for any help.
CHeers
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Per informazioni si veda http://www.gnupg.org
iD8DBQE99P5GIRaQQEznKxURAoZlAKCXRVAXnLsZVIRA7Qdy9yAJ7+HUIQCdHYCv
hTN+xlKwt0qZ8m2f40zV/Dk=
=gyYl
-----END PGP SIGNATURE-----
