[GRASSLIST:5203] Re: Extracting line data & poitn data form a file.
Radim Blazek
blazek at itc.it
Tue Dec 10 04:58:52 EST 2002
On Monday 09 December 2002 09:34 pm, Antonio G. - Geotronix wrote:
> Hash: SHA1
> Hi.
> I have a vect file in which I have both point data (elevation points,
> mountain peaks & so on) and line data (equal elevation lines of
> topografic map). I would like to separate the two types of data so as to
> generate two diffrent files, one holding the point data and the other
> the line data. This is because having them in the same file makes a lot
> of confusion while having them in two diffrent file make things a bit
> clearer.
> Thanks in advance for any help.
> CHeers
Something like:
v.extract type=site list=1-1000000000
v.extract type=line list=1-1000000000
Radim
