[GRASSLIST:5210] RE: g.region help
Glynn Clements glynn.clements at virgin.net
Tue Dec 10 19:19:11 EST 2002
John Gillette wrote:
> A quick check of main.c for r.in.arc looks like it is supposed
> to set the "active region" from information in the header
> of the input file.  It also uses the number of rows and columns
> from the header to read in the data.
> Are you sure the raster file size changed?
> John
> (Can a developer check me here?)
r.in.arc sets the imported map's region from the file; it doesn't
change the current region.
Glynn Clements <glynn.clements at virgin.net>
