[GRASSLIST:5250] Re: install-grass51 No rule to make target `bitmap.c'
    Markus Neteler
    neteler at itc.it
    Mon Dec 30 06:24:49 EST 2002
On Sun, Dec 29, 2002 at 04:05:12PM +0100, Piero Cavalieri wrote:
> Nico Hardebol wrote:
> >Dear all,
> >While doing - grass 5.1 Make - I get an error due to No rule to make target
> >bitmap.c'.
> >I use grass51src_cvs_snapshot_exp_2002_12_2 and
> >grass50src_cvs_snapshot_exp_2002_12_20, install the software under Suse linux
> >7.2
> >and do:
> >CFLAGS="-g -Wall" ./configure --with-grass50=../grass50_exp_2002_12_20
> >--with-postgres-includes=/usr/local/pgsql/include
> >(for some reason the postgres-includes can not be found so
> >--with-postgres-includes....... etc.)
> >The compilation is succesful:
> >GRASS is now configured for i686-pc-linux-gnu
> >make mix
> >./tools/link -old=../grass50_exp_2002_12_20 -new=./ -conf=./tools/link.conf
> >Linking
> >Subdir ignored: ../grass50_exp_2002_12_20/src/include/CVS
> >Subdir ignored: ../grass50_exp_2002_12_20/src/include/geom
> >Subdir ignored: ../grass50_exp_2002_12_20/src/include/vect
> >Subdir ignored: ../grass50_exp_2002_12_20/src/libes/bitmap/CVS ......
> >make mix = also succesful
> >.... although some subdir's are ignored:
> >but these are not linked yet (true?)
I have changed the message. Now above is no longer printed, but
the assigned links:
Linked /thuille1/ssi/cvsgrass_exp/src/include/winname.h.in
Linked /thuille1/ssi/cvsgrass_exp/src/libes/bitmap/bitmap.c
Linked /thuille1/ssi/cvsgrass_exp/src/libes/bitmap/main.c
Linked /thuille1/ssi/cvsgrass_exp/src/libes/bitmap/smain.c
Linked /thuille1/ssi/cvsgrass_exp/src/libes/bitmap/sparse.c
Linked /thuille1/ssi/cvsgrass_exp/src/libes/btree/create.c
> >make or ( make 2>&1 | tee compileOutput.log )
> >problems arises:
> >the  compileOutput.log shows:
> >compileOutput.log:
> >make[1]: Entering directory `/home/harj/gis/grass/grass51_exp_2002_12_20/lib'
> >bitmap
> >make[2]: Entering directory
> >`/home/harj/gis/grass/grass51_exp_2002_12_20/lib/bitmap'
> >make[2]: *** No rule to make target `bitmap.c', needed by
> >`OBJ.i686-pc-linux-gnu/bitmap.o'.  Stop.
> >make[2]: Leaving directory
> >make[1]: *** [subdirs] Error 1
> >make[1]: Leaving directory `/home/harj/gis/grass/grass51_exp_2002_12_20/lib'
> >make: *** [default] Error 1
> >Any ideas?
Are you sure that bitmap.c is present in your 5.0 source code?
If yes, are permissions correct?
It should work (does for me).
Best,
 Markus Neteler
