[GRASSLIST:5251] Re: install-grass51 No rule to make target `bitmap.c' - solved
Nico Hardebol
harj at geo.vu.nl
Mon Dec 30 08:40:07 EST 2002
Dear all,
in reaction on the comments by: Glynn Clements; Piero Cavalieri; Markus
Neteler on the problem of getting an error due to No rule to make target
bitmap.c'.
Actually the first comments of Glynn Clements of [Date: Thu, 26 Dec 2002
21:27:46 +0000] was right, he wrote:
"2. The argument to --with-grass50= should be an *absolute* path, not a
relative path; it has to be valid from any directory, not just the
top-level directory."
and indeed this stupid guy had descibed the path relatively, although checked
several times - changing it into an abolute one solves the problem.
thank you all
