[GRASSLIST:3067] Re: NVIZ2.2 compile error. Missing tkIntDecls.h?
John Gillette
JGillette at rfmd.com
Fri Feb 1 18:13:15 EST 2002
I figured something out.
.../grass5.0.0pre3/src.contrib/GMSL/NVIZ2.2/src contains togl.c.
This checks your system for version number of tk and causes some
inclusions:
togl.c -|--> tkInt8.1.1.h -->tkIntDecls.h
|--> tkInt8.2.3.h -->tkIntDecls.h
|--> tkInt8.3.h --->tkIntDecls8.3.h
All the files are in .../NVIZ2.2/src EXCEPT tkIntDecls.h
which doesn't exist. Therefore, if your system has tk8.1 or
8.2 it will fail to compile NVIZ. I have 8.1, it looks like
Paul Kelly has 8.2 and they fail. I bet the new precompiled
version uses 8.3.
I think that this is a bug in the installation.
I "fixed" it by copying tkIntDecls8.3.h to tkintDecls.h in the
same directory. Recompiled, it works, I can run NVIZ.
The danger is that the file I created may not be correct for
tk8.1 or 2.
I work on a system for which I am not an administrator. If you
have your own system, just get tk8.3 and it's a non issue.
John Gillette
