[GRASSLIST:3072] Re: Grid 3d
Markus Neteler
neteler at itc.it
Sat Feb 2 13:41:47 EST 2002
Hi Henning,
On Sat, Feb 02, 2002 at 04:55:34PM +0100, Henning Ries wrote:
> Hello
> I want to use the Grid 3d modules. But unfortunately I can not find them
> anywhere in the source code distribution of Grass5pre3 (besides s.vol.rst).
> Do I have to compile the Grid 3d modules separately? If yes, where can I find
> the code?
> Thanks & Regards
> Henning
The code is available in the experimental tree in CVS. It is not
included into the release branch as there are severe bugs inside
(confusion with orientation of coordinate system etc.).
The bugs are documented, also more comments. We still search for
a programmer to fix the code. It should not be too difficult...
Let me know if you are interested to look into the problems (or
someone else from the list). I can send further hints.
Best regards,
Markus Neteler
