[GRASSLIST:3079] Re: input images
felipem
felipem at linuxfreemail.com
Sun Feb 3 17:37:16 EST 2002
Hi Markus
I made this:
In imagery LOCATION ran:
- i.group --> with spot.ms.1 spot.ms.2 spot.ms.3
- i.target --> for spearfish LOCATION and PERMANENT MAPSET
- i.points --> with 10 points and overall rms error equal to 6.86
- i.rectify --> ok
And now I know how geocoding spot imagery!
But if the imagery don't belong to a GRASS location or are not in a tape (for
to use the i.tape commands), for example in another hard disk or CDROM.
-->What is the correct method to enter this imagery to GRASS?
To test I made this:
1. To create "spot2" LOCATION with image information from the header, N-S and
E-W limits, x,y system and resolution
2. To create cell and cellhd directories on spot2/PERMANENT
3. To copy images files and header files spot2/PERMANENT/cell and
spot/PERMANENT/cellhd respectively
4. To run r.support for creating other support files.
Thank you,
felipe
UN Colombia
