[GRASSLIST:3085] Re: TIGER/Line Data
Ben Logan
ben at wblogan.net
Sun Feb 3 21:27:11 EST 2002
On Sun, Feb 03, 2002 at 01:30:33PM -0700, Roger Miller wrote:
> On Sunday 03 February 2002 12:50, you wrote:
> > Does GRASS support the TIGER/Line data format used by the Census
> > Bureau? I looked on the GRASS homepage, but couldn't find anything
> > about it.
> I did this recently with Tiger 2K county data. I used v.in.tig.basic. I got
> the lines themselves, but I didn't get the topology or the attributes.
I created a new GRASS location using lat/long as a coord system, grs80
as the spheroid, and nad83 as the datum. I used the default region
and figured I could always change that later. I also created a mapset
called "carroll" (the name of my county) to hold the maps.
I then downloaded the TIGER/Line 1997 file of my county (tgr51035.zip)
and unzipped it into a directory. Here's the command I used to import
them:
v.in.tig.basic t1=TGR51035.RT1 t2=TGR51035.RT2 out=carroll spheroid=grs80
(I assumed that I didn't need to use the 'zone' option since my
location uses lat/long.)
It ran for awhile and didn't produce any errors. I then set the
region:
g.region vect=carroll
And used d.vect to display the map. Nothing showed up, though, until
I ran v.support on the new map.
Even now, the map looks slightly distorted (could be my imagination
though) and when I try to zoom in with d.zoom, it won't let me get
close at all. Did I do something wrong with the coordinate system?
Thanks,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
