[GRASSLIST:3116] v.support and general vector question
    I.T.H. Deyzel
    izak at metsys.weathersa.co.za
    Mon Feb 11 08:09:12 EST 2002
Good day all,
I hope someone can help me.
I've compiled pre3 on RH7.2
I've imported a vector catchment file from .e00 using m.in.e00. The file
is imported succesfully but I can't seem to get the attributes and
labels to correspond. I did copy the 'catch.catnum' file as 'catch' so
that the category file correspond to the vector's name. If I query the
vector field I get the incorrect label information. I've tried importing
with m.in.e00 -i option, but to no avail. Have anyone experienced such
difficulties using m.in.e00? It might be that the .e00 encoding differs
a bit from what m.in.e00 expects or else I'm missing something.
I've been trying to fix the dig_att and dig_cats files manually so that
they correspond to reality (what a tedious task!), but when running
v.support I get errors unknown to me. Please help.
* the error : PNT_TO_AREA failed: (29.150000, -22.210000) (Category 2) -
does it indicate that the polygon is open and that is unable to label
it?
* WARNING: area 20 label: 17 matched another label: 22. - is the label
positions to close together? How can I fix this.
Thank you for your help. Apprecieated.
Here follows the complete output from v.support:
   V.SUPPORT:
Selected information from vector header
 Organization:
 Map Name:      catch
 Source Date:
 Orig. Scale:   100000
 No snapping will be done
    Reading Vector file.
    100%
    Building areas
    Building islands
    Attaching labels
PNT_TO_AREA failed: (31.510000, -22.450000) (Category 7)
PNT_TO_AREA failed: (28.580000, -22.510000) (Category 13)
WARNING: area 39 label: 40 matched another label: 60.
WARNING: area 40 label: 39 matched another label: 61.
WARNING: area 77 label: 73 matched another label: 77.
WARNING: area 69 label: 70 matched another label: 78.
WARNING: area 112 label: 91 matched another label: 101.
WARNING: area 86 label: 93 matched another label: 107.
WARNING: area 111 label: 110 matched another label: 114.
WARNING: area 110 label: 118 matched another label: 128.
WARNING: area 163 label: 19 matched another label: 152.
WARNING: area 149 label: 157 matched another label: 218.
WARNING: area 229 label: 222 matched another label: 234.
WARNING: area 215 label: 205 matched another label: 236.
WARNING: area 261 label: 247 matched another label: 275.
WARNING: area 278 label: 241 matched another label: 278.
WARNING: area 281 label: 263 matched another label: 280.
WARNING: area 137 label: 134 matched another label: 310.
WARNING: area 365 label: 197 matched another label: 369.
WARNING: area 349 label: 355 matched another label: 386.
WARNING: area 389 label: 388 matched another label: 399.
WARNING: area 291 label: 360 matched another label: 432.
WARNING: area 431 label: 403 matched another label: 433.
WARNING: area 466 label: 75 matched another label: 464.
WARNING: area 449 label: 445 matched another label: 472.
WARNING: area 482 label: 434 matched another label: 485.
WARNING: area 486 label: 455 matched another label: 493.
WARNING: area 492 label: 497 matched another label: 502.
WARNING: area 448 label: 454 matched another label: 511.
WARNING: area 584 label: 589 matched another label: 592.
WARNING: area 560 label: 568 matched another label: 616.
WARNING: area 617 label: 630 matched another label: 633.
PNT_TO_AREA failed: (28.260000, 28.080000) (Category 650)
WARNING: area 709 label: 644 matched another label: 683.
WARNING: area 686 label: 690 matched another label: 723.
PNT_TO_AREA failed: (29.160000, 28.510000) (Category 732)
WARNING: area 872 label: 833 matched another label: 847.
 Number of lines:   6092
 Number of nodes:   4147
 Number of areas:   1946
 Number of isles:   1
 Number of atts :   466
 Number of unattached atts :   5
 Snapped lines  :   0
Thank you,
Izak
I.T.H. Deyzel
METSYS
Tel: +27 58 303 5571
Visit METSYS website at : http://metsys.weathersa.co.za
