[GRASSLIST:3123] Re: Problem using Monitors from a fully scripted GRASS session
    Glynn Clements
    glynn.clements at virgin.net
    Mon Feb 11 16:30:28 EST 2002
Karine ZUERCHER wrote:
> Until grass5pre1, I used HTMLMAP monitor driver from a script (adapted from
> grasslinks) opening and closing a grass session. But as I now updated to
> grass5pre3 (self-compiled version on a RH7.2), I get the following error
> message:
> You must start this driver from within GRASS
This indicates that LOCATION isn't set.
As none of the drivers actually use the value of this variable, I've
removed the check.
Note: $GISBASE/etc/Init.sh sets LOCATION to:
	$GISDBASE/$LOCATION_NAME/$MAPSET
It shouldn't matter whether LOCATION is set, as programs should use
the individual components.
Glynn Clements <glynn.clements at virgin.net>
