Hi I need to import some ER Mapper files into grass5.x In the past I have used erm2grass, which works with integer data in GRASS4.X. The problem is that a lot of the data that I use are floating point. Has anyone got a script to do this, or is it time to brush up my perl. Cheers Henk
