[GRASSLIST:3186] Re: Set $GISDBASE without running GRASS ?
Glynn Clements
glynn.clements at virgin.net
Thu Feb 21 22:58:17 EST 2002
Julien wrote:
> I made a mistake while GRASS was processing : I've killed the X server.
> Now, when restarting GRASS, the init.sh script has no value for the
> $GISDBASE variable (parameter null or not set).
> I was wondering if it was possible to set the directory containing the
> geographic locations for $GISDBASE without GRASS (which can not be
> started) ?
> Or is there another means to resolve this problem ?
Either edit ~/.grassrc5 manually, or just delete it.
Glynn Clements <glynn.clements at virgin.net>
