[GRASSLIST:3225] Re: Missing 'output' in d.his (& d.shadedmap)
Karine ZUERCHER kzuerch at yahoo.com
Tue Feb 26 05:49:42 EST 2002
On Tuesday 26 February 2002 10:36, Glynn Clements wrote:
> Karine ZUERCHER wrote:
> > Until Grass5beta11, I used to create shaded maps with d.shadedmap tcltk
> > module, but with grass5.0.0pre3 I realized I could no longer write an
> > output map. In fact it is the d.his module that no longer has an optional
> > output option.
> This functionality is now provided by r.his. r.his creates separate
> R/G/B output layers; you can use r.composite to generate a composite
> colour layer if you need to (although I'm not aware of any situation
> where this is required).
Actually, I need it to get a shaded raster map...
Thanks for the typ, although it's a longer way, it works fine.
Still, if possible, I would suggest the reput the d.his  (& d.shadedmap)
output option !
In Kindness
Karine
Karine ZUERCHER
