[GRASSLIST:3223] Re: Missing 'output' in d.his (& d.shadedmap)
Glynn Clements glynn.clements at virgin.net
Tue Feb 26 04:36:39 EST 2002
Karine ZUERCHER wrote:
> Until Grass5beta11, I used to create shaded maps with d.shadedmap tcltk
> module, but with grass5.0.0pre3 I realized I could no longer write an output
> map. In fact it is the d.his module that no longer has an optional output
> option.
This functionality is now provided by r.his. r.his creates separate
R/G/B output layers; you can use r.composite to generate a composite
colour layer if you need to (although I'm not aware of any situation
where this is required).
Glynn Clements <glynn.clements at virgin.net>
