[GRASSLIST:3226] Re: Exporting grass raster to MapInfo
    Kevin Slover
    kjslover at nhc.noaa.gov
    Tue Feb 26 08:55:43 EST 2002
Gordon,
    I have done this several times, and have found that the best way to do
it is to use r.out.tiff...the format would be something like: r.out.tiff
-tv input=x output=y  [t=export .tfw file, v=verbos].  The command already
places a .tif ending on the file, so there is no need to set
output=raster.tif, simply output=raster. Note that MapInfo is not too keen
on using tiled tiffs, so ensure that you do not export a tiled tiff.  Of
course, to bring this into MapInfo, use WorldReg....
Hope this helps.  Let me know if you run into any problems.  Cheers
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20020226/263ec5c6/attachment.html
