[GRASSLIST:3261] RE: NVIZ2.2 compile error TkIntDecls.h redux
Markus Neteler
neteler at itc.it
Thu Feb 28 15:35:16 EST 2002
On Thu, Feb 28, 2002 at 02:24:20PM -0500, John Gillette wrote:
> It looks like a tcl problem to me. (Just guessing, I am not a
> programmer). The scripts subdirectory is full of the tcl script
> files.
> The "fix" I used of renaming the header files worked for me BUT
> I don't think this is a good fix because the headers COULD be
> different for different versions of tcl/tk. See [GRASSLIST:3100]
> in which Markus says "o.k., I have added the missing files.
> Now we have:" and goes on to list the changes made. I assume he
> ment that he added these into the CVS file.
Yes, to CVS. Sorry, I wasn't clear on that probably.
> Check the CVS
> RELEASE branch snapshot (NOT experimental branch). All you need
> is the correct header file (I hope). Try un-taring the snapshot
> and search for the headers in .../src.contrib/GMSL/NVIZ2.2/src/
You can also use the latest CVS snapshot:
http://grass.itc.it/download.html
Or, even easier, extract the file from the web-CVS:
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.contrib/GMSL/NVIZ2.2/src/
and download the include files from there.
> If this doesn't fix it, you will need more "expert" help than
> mine. If you need more help include information on OS and
> library versions.
> John Gillette
Markus Neteler
> > -----Original Message-----
> > From: Andrew [mailto:andrew at quakes.potsdam.edu]
> > Sent: Thursday, February 28, 2002 1:37 PM
> > To: John Gillette
> > Subject: Re: [GRASSLIST:3258] RE: NVIZ2.2 compile error TkIntDecls.h
> > redux
> > > I have these suggestions:
> > > (1) look at your region settings. Too large a region will slow
> > > NVIZ down considerably. I made this mistake the first time I
> > > ran it. Try something small like 501 X 501 rows and cols
> > 675 X 500, .01 degrees separation in both x and y for
> > coverage of NY state
> > and eastern Pennsylvania.
> > > (2) Try a CVS snapshot to compile. I believe Markus fixed the
> > > header file issue for the compile issue.
> > I fixed the include file problem before I wrote. It was an
> > obvious "rename"
> > based upon the information in the files listed in the error
> > message. I found
> > Marcus' response on the list when I searched on the problem
> > and recompiled
> > one more time. I have never worked from CVS, I try to always
> > take the latest
> > stable package of things and then search the recent lists if things go
> > phlooey. I have found no mention of this particular behavior
> > to suggest CVS
> > should be necessary. I don't mind learning new things, but I am bit
> > overextended ...
> > > (3) Tell us exactly what messages you get as it starts up. I
> > > get the following:
> > > Loading Data
> > > Loading Data
> > > translating colors
> > > Adding panels from /scratch/grass5p3/grass5/etc/nviz2.2/scripts
> > Exactly this much. The program is still active, appears as a
> > process, can be
> > paused and continued indefinitely, can be exited by right
> > clicking the start
> > up form, etc, but nothing else happens and nothing dies on
> > its own as noted
> > previously. I tried to start from the grass command line and
> > got no panels,
> > but the program proceded to the same place before "losing
> > contact" with my
> > need.
> > There were no other errors or significant warnings that I
> > noticed during the
> > recompiles.
> > > I have attempted to start nviz from the TclTkgrass
> > interface (and from
> > > the grass command line). The program starts and opens the "waiting"
> > > window, prints the line about loading the panels from the
> > index (default
> > > /usr/local/grass5/etc/nviz2.2/scripts/panelIndex) and goes into an
> > > infinite do-nothing mode. I can stop and continue from the startup
> > > interface button, exit by right clicking, but nothing else happens.
> > > Suggestions from anyone?
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
