[GRASSLIST:2852] Re: d.mon can't bind to socket
Anthony Morton abmorton at mac.com
Thu Jan 3 22:55:26 EST 2002
 > Eric G. Miller wrote:
 >> Do you get a directory /tmp/grass-$USER (where $USER is your login)?
 >> And if so, does it contain anything? (like a file called "x0").
 > On Thursday, January 3, 2002, at 07:29  PM, Glynn Clements wrote:
 > AFAICT, this was changed after pre2.
 > "cvs log src/libes/gis/unix_socks.c" says that pre2 (2001/09/13) was
 > version 1.5.4.1 (2001/08/01), but the change was made in version
 > 1.5.4.2 (2001/10/08).
I'm definitely using pre2 which is dated September 2001.  There are no
grass-related files in /tmp either before or after I try starting a
monitor.  (There is an .X0-lock file which appears to be associated with
X11.)  I appear to have write permission on /tmp, given that I can touch
files there manually.
Should I perhaps try rolling my own GRASS from the latest sources?
Tony M.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020104/3cb2b2db/attachment.bin
