[GRASSLIST:2863] Re: Compilation problem w/5pre2: flate.c (zlib?)
Markus Neteler neteler at itc.it
Sat Jan 5 16:55:43 EST 2002
On Sat, Jan 05, 2002 at 02:14:52PM -0500, nsmith at holycross.edu wrote:
> >> I'm failing to complie GRASS5pre2 on YellowDogLinux.
> > It's quite possibly related to the fact that one of the PostgreSQL
> > headers is called "config.h". Try configuring without using
> > /usr/include for any of the --with-includes or
> > --with-[whatever]-includes
> > switches.
> > If that doesn't work, you'll need to use a more recent version of
> > GRASS (e.g. a CVS snapshot). GRASS' own src/include directory should
> > take precedence over all system include directories in recent
> > versions.
> > Glynn Clements <glynn.clements at virgin.net>
> This was exactly the problem.  I misread or was misled by the INSTALL
> doc and used the generic --with-include to set the postgres include
> directory:  running configure with a specific --with-postgres-include
> and nothing else cleared up the problem.
> Thanks for the quick help!
Neel,
if you have suggestions to make INSTALL clear for this issue, please
let me know.
Thanks,
Markus Neteler
