Hi I have just tried to read an ASTER image into grass5, and discovered that r.in.hdf is not implemented in grass5. Do I need to install grass4 as well to do this. Also, will r.in.hdf be able to read the 16-bit thermal bands from the hdf file. Cheers Henk Coetzee
