[GRASSLIST:2918] Re: map server
Markus Neteler
neteler at itc.it
Thu Jan 17 08:51:46 EST 2002
On Thu, Jan 17, 2002 at 12:52:32PM +0100, Andrea Aime wrote:
> Wow Markus, wonderful!!!
> Is it straightforward to set up or does it still need a good
> developer and a lot of work? (I mean, is this something
> that has been done by itc/irst developers or is something publicly
> available?)
well... it's quite easy (10 minutes?). Just add the GRASS layer to
a working MapServer and compile libgrass into GDAL.
> Is there any howto describing how to publish a GRASS mapset on the
> net with mapserver? A setup guide?
Coming soon, I'll prepare something. The only tricky parts are
- compiling libgrass into GDAL (o.k., not really difficult)
- make the system find the .grassrc5 which you have to provide
(just find the $HOME of the Apache server)
I have already added some MapServer related comments into
the README of libgrass from Frank Warmerdam. From that you
will be able to install it.
Later, when libgrass will read also GRASS vector and sites data
directly, we will have full LOCATION access. Then it becomes really
great.
Ciao
Markus
> ----- Original Message -----
> From: "Markus Neteler" <neteler at itc.it>
> To: <GRASSLIST at baylor.edu>
> Sent: Thursday, January 17, 2002 11:57 AM
> Subject: [GRASSLIST:2915] Re: map server
> > On Thu, Jan 17, 2002 at 11:39:29AM +0100, Bernhard Reiter wrote:
> > > On Thu, Jan 17, 2002 at 12:05:49PM +0200, Ahmet Temiz wrote:
> > > > I would like to display some maps which have been created
> > > > with grass5 on the internet.
> > > I assume that you've got maps in raster format.
> > > > How can I do that ?
> > > Then you can save them as normal images depending on the size.
> > > Try the PNG format.
> > > If they are really big, you could use MapIt! to server tiled PNGs.
> > > www.mapit.de/index.en.html
> > > > Which map server is compatible with grass?
> > > Mapserver also can also serve a lot of GRASS stuff.
> > > You find link to these from:
> > > http://freegis.org/browse.en.html?category=app&app=web_mapping
> > You can see here a simple Mapserver/GRASS implementation
> > at work:
> > http://grass.itc.it/start.html
> > Markus Neteler
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
