[GRASSLIST:2916] Re: map server
Andrea Aime aaime at libero.it
Thu Jan 17 06:52:32 EST 2002
Wow Markus, wonderful!!!
Is it straightforward to set up or does it still need a good
developer and a lot of work? (I mean, is this something
that has been done by itc/irst developers or is something publicly
available?)
Is there any howto describing how to publish a GRASS mapset on the
net with mapserver? A setup guide?
Ciao
Andrea
----- Original Message -----
To: <GRASSLIST at baylor.edu>
Sent: Thursday, January 17, 2002 11:57 AM
Subject: [GRASSLIST:2915] Re: map server
> On Thu, Jan 17, 2002 at 11:39:29AM +0100, Bernhard Reiter wrote:
> > On Thu, Jan 17, 2002 at 12:05:49PM +0200, Ahmet Temiz wrote:
> > >    I would like to display some maps which have been created
> > >    with grass5 on the internet.
> > I assume that you've got maps in raster format.
> > > How can I do that ?
> > Then you can save them as normal images depending on the size.
> > Try the PNG format.
> > If they are really big, you could use MapIt! to server tiled PNGs.
> > www.mapit.de/index.en.html
> > >    Which map server is compatible with grass?
> > Mapserver also can also serve a lot of GRASS stuff.
> > You find link to these from:
> > http://freegis.org/browse.en.html?category=app&app=web_mapping
> You can see here a simple Mapserver/GRASS implementation
> at work:
>    http://grass.itc.it/start.html
> Markus Neteler
