[GRASSLIST:2915] Re: map server
    Markus Neteler
    neteler at itc.it
    Thu Jan 17 05:57:37 EST 2002
On Thu, Jan 17, 2002 at 11:39:29AM +0100, Bernhard Reiter wrote:
> On Thu, Jan 17, 2002 at 12:05:49PM +0200, Ahmet Temiz wrote:
> >    I would like to display some maps which have been created
> >    with grass5 on the internet.
> I assume that you've got maps in raster format.
> > How can I do that ?
> Then you can save them as normal images depending on the size.
> Try the PNG format.
> If they are really big, you could use MapIt! to server tiled PNGs.
> 	www.mapit.de/index.en.html
> >    Which map server is compatible with grass?
> Mapserver also can also serve a lot of GRASS stuff.
> You find link to these from:
> 	http://freegis.org/browse.en.html?category=app&app=web_mapping
You can see here a simple Mapserver/GRASS implementation
at work:
   http://grass.itc.it/start.html
Markus Neteler
