[GRASSLIST:2929] Problems with Grass on XFree/Cygwin und WindowsXP
Henning Lorenz hl at geofys.uu.se
Fri Jan 18 03:20:38 EST 2002
Hello!
I installed Grass for the first time on a computer running under
Windows. There are some problems I never encountered on Linux and
MacOSX.
Grass without XFree is fine.
On XFree it starts the first welcome screen. After pressing enter it
terminates with an "cannot open xterm" error (grass shouldn't open a
window before having specified the region?!) There was a similar
thread with another Xserver in August 2001, but that solution doesn't
work for me.
There are two other problems when starting up XFree. Xauthority is
missing (the main problem?). How can I create a  Xauthority file
working with Grass? And some files should be set to root as owner.
How can I activate root in cygwin? It's not in the documentation.
Thanks for helping!
Henning
Henning Lorenz
Uppsala University
Department of Earth Sciences
Villavägen 16
S-752 36 Uppsala
phone:	+46(0)18 471-7161
fax: 	+46(0)18 50 11 10
priv. 	+46(0)18 463 273
mobil 	+46(0)733 622 655
mailto:hl at geofys.uu.se
