[GRASSLIST:2934] Importing intersectioning Raster-Files
Harald Wehr hwehr at hs-harz.de
Fri Jan 18 05:46:43 EST 2002
Hi GrassList,
I 've got several tiff-files, each with a corresponding tfw-file.
Unfortunately the files intersect a little bit with each other, as each
tiff-file has got an empty margin surrounding the map. Consider
following picture:
Map 1:                              I---------->6<
                                     I >4<--->3< I
                                     I  I     I  I
                                     I  I     I  I
                                     I >1<--->2< I
                                    >5<----------I
Map 2:                              I---------->6<
                                     I >4<--->3< I
                                     I  I     I  I
                                     I  I     I  I
                                     I >1<--->2< I
                                    >5<----------I
Each tiff-file contains everything from 5 to 6 while the actual
information is within 1,2,3,4. In this example the points 1,2 from map 1
would correspond to 4,3 from map 2.
Is it possible to produce one raster that contains all maps only with
the relevant information from each tiff between the inner rectangle?
Thanks in advance
Harald
