[GRASSLIST:2930] d.mon problem (again ...)
Emmanuel Poizot
poizot at cnam.fr
Fri Jan 18 09:50:37 EST 2002
I a newby under GRASS world.
I install it under Linux (Mandrake 8.1) and I used the binary packages.
Install was ok and I download some data from USGS to make some tests.
The import was ok, but by the time I'd wanted to display, I start a
minotor, wich appears
and when I tried to display the datas, I got the messages :
-- No graphics monitor has been selected for output.
Please run "d.mon" to select a graphics monitor.
which normaly should be the screen actualy open.
Any idear ?
Cordialement
Emmanuel Poizot
CNAM/INTECHMER
B.P. 324
50103 Cherbourg Cedex
Tél : (33) (0)2 33 88 73 42
Fax : (33) (0)2 33 88 73 39
