[GRASSLIST:2984] Re: r.water.outlet
Glynn Clements glynn.clements at virgin.net
Thu Jan 24 09:38:58 EST 2002
Markus Neteler wrote:
> > I need some advice.
> > In the email from Glynn Clements I read that r.water.outlet was disabled
> > due to bugs.
> > Is there an alternative in GRASS to generate a watershed basin for a
> > given outlet point?
> eventually there is some confusion: In fact the r.water.outlet should
> be functional. And AFAIK it is not disabled.
	$ fgrep -B1 r.water.outlet src/CMD/lists/GRASS
	#doesn't work properly:
	#src/raster/r.water.outlet
	$ cvs log src/CMD/lists/GRASS | fgrep -B2 r.water.outlet
	revision 1.92.2.24
	date: 2002/01/04 17:32:37;  author: markus;  state: Exp;  lines: +2 -1
	commented r.water.outlet as non functional
Just to clarify matters: Bärbel is presumably referring to my response
to the recent message from Daniel Tourde. I simply looked up the
missing programs in src/CMD/lists/GRASS, and my response was based
upon what was in that file, plus the results from "cvs log".
Glynn Clements <glynn.clements at virgin.net>
