[GRASSLIST:2986] Re: r.water.outlet
Markus Neteler
neteler at itc.it
Thu Jan 24 10:04:39 EST 2002
On Thu, Jan 24, 2002 at 02:38:58PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > I need some advice.
> > > In the email from Glynn Clements I read that r.water.outlet was disabled
> > > due to bugs.
> > > Is there an alternative in GRASS to generate a watershed basin for a
> > > given outlet point?
> > eventually there is some confusion: In fact the r.water.outlet should
> > be functional. And AFAIK it is not disabled.
> $ fgrep -B1 r.water.outlet src/CMD/lists/GRASS
> #doesn't work properly:
> #src/raster/r.water.outlet
> $ cvs log src/CMD/lists/GRASS | fgrep -B2 r.water.outlet
> revision 1.92.2.24
> date: 2002/01/04 17:32:37; author: markus; state: Exp; lines: +2 -1
> commented r.water.outlet as non functional
> Just to clarify matters: Bärbel is presumably referring to my response
> to the recent message from Daniel Tourde. I simply looked up the
> missing programs in src/CMD/lists/GRASS, and my response was based
> upon what was in that file, plus the results from "cvs log".
O.k. - it was not re-enabled in the list. Well,
re-enabled now...
Bärbel, if it is not present in your binaries, I can probably
send you the module in a small package (which platform?).
Markus
