[GRASSLIST:3000] Re: GRASS pre 3 on RedHat 7.2
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Jan 25 16:34:33 EST 2002
Daniel Tourde wrote:
> Hi,
> > > Requires: GRASS = 5.0.0pre3 ld-linux.so.2 libc.so.6 libdl.so.2 libm.so.6
> > > libodbc.so.1 libpthread.so.0 libz.so.1 libc.so.6(_2.0)
> > > libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3)
> > A full build requires a bit more than that. For my system (RH6.2):
> You are probably right but I did not specify all these directories. RPM
> did it for me. I don't know how I can modify the .spec file to reflect
> the reality. I am sorry.
Hi Daniel,
if you compile on linux, you may use the script find_dl.sh from the
tools directory of the source to produce a complete list of
dependencies.
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
