[GRASSLIST:2973] Re: GRASS pre 3 on RedHat 7.2
Daniel Tourde ted at foi.se
Wed Jan 23 09:07:12 EST 2002
> > Requires: GRASS = 5.0.0pre3 ld-linux.so.2 libc.so.6 libdl.so.2 libm.so.6
> > libodbc.so.1 libpthread.so.0 libz.so.1 libc.so.6(_2.0)
> > libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3)
> A full build requires a bit more than that. For my system (RH6.2):
You are probably right but I did not specify all these directories. RPM
did it for me. I don't know how I can modify the .spec file to reflect
the reality. I am sorry.
			Daniel
> All programs require:
>         /lib/ld-linux.so.2
>         libc.so.6
>         libm.so.6
>         libz.so.1
> Several programs require:
>         libncurses.so.4
>         libtermcap.so.2
> PostgreSQL programs require:
>         libpq.so.2.0
>         libcrypt.so.1
> r.in.gdal requires:
>         libgdal.1.1.so
>         libdl.so.2
>         libstdc++-libc6.1-1.so.2
>         libtiff.so.3
>         libjpeg.so.62
>         libpng.so.2
> r.{in,out}.png require:
>         libpng.so.2
> r.{in,out}.tiff require:
>         libtiff.so.3
>         libjpeg.so.62
> d.text.freetype requires:
>         libfreetype.so.6
> xganim requires:
>         libICE.so.6
>         libSM.so.6
>         libX11.so.6
>         libXext.so.6
>         libXm.so.2
>         libXp.so.6
>         libXt.so.6
>         libdl.so.2
> NVIZ requires:
>         libICE.so.6
>         libSM.so.6
>         libX11.so.6
>         libXext.so.6
>         libXt.so.6
>         libXmu.so.6
>         libtk.so
>         libtcl.so
>         libGLU.so.1
>         libGL.so.1
>         libdl.so.2
>         libpq.so.2.0
>         libtiff.so.3
>         libpthread.so.0
>         libcrypt.so.1
>         libjpeg.so.62
> Also, the PNG driver requires:
>         libgd.so.2
> plus anything which libgd is linked against (JPEG, PNG, FreeType, Xpm
> and X libraries are all candidates).
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
