[GRASSLIST:2972] Re: GRASS pre 3 on RedHat 7.2
Glynn Clements
glynn.clements at virgin.net
Wed Jan 23 07:34:49 EST 2002
Daniel Tourde wrote:
> Hej Markus,
> > please send them to me (attachment), I'll put them into the CVS.
> > Thanks a lot,
> Here is what the .spec file produced as errors (remember I used the one
> from pre2). It seems that some files have either changed place,
> disappeared or have not build for me.
> Could you please tell me what I am supposed to do?
> Remove these files from the content of the rpms, move them or try to
> determine why they never built.
> Thanks in advance
> Daniel
> Requires: GRASS = 5.0.0pre3 ld-linux.so.2 libc.so.6 libdl.so.2 libm.so.6
> libodbc.so.1 libpthread.so.0 libz.so.1 libc.so.6(_2.0)
> libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3)
A full build requires a bit more than that. For my system (RH6.2):
All programs require:
/lib/ld-linux.so.2
libc.so.6
libm.so.6
libz.so.1
Several programs require:
libncurses.so.4
libtermcap.so.2
PostgreSQL programs require:
libpq.so.2.0
libcrypt.so.1
r.in.gdal requires:
libgdal.1.1.so
libdl.so.2
libstdc++-libc6.1-1.so.2
libtiff.so.3
libjpeg.so.62
libpng.so.2
r.{in,out}.png require:
libpng.so.2
r.{in,out}.tiff require:
libtiff.so.3
libjpeg.so.62
d.text.freetype requires:
libfreetype.so.6
xganim requires:
libICE.so.6
libSM.so.6
libX11.so.6
libXext.so.6
libXm.so.2
libXp.so.6
libXt.so.6
libdl.so.2
NVIZ requires:
libICE.so.6
libSM.so.6
libX11.so.6
libXext.so.6
libXt.so.6
libXmu.so.6
libtk.so
libtcl.so
libGLU.so.1
libGL.so.1
libdl.so.2
libpq.so.2.0
libtiff.so.3
libpthread.so.0
libcrypt.so.1
libjpeg.so.62
Also, the PNG driver requires:
libgd.so.2
plus anything which libgd is linked against (JPEG, PNG, FreeType, Xpm
and X libraries are all candidates).
> RPM build errors:
> File not found: /opt/grass/grass5/bin/d.leg.thin
> File not found: /opt/grass/grass5/bin/i.grey.scale
These have been removed.
> File not found: /opt/grass/grass5/bin/r.combine
For some reason, this is in $GISBASE/etc.
> File not found: /opt/grass/grass5/bin/r.resamp.rst
> File not found: /opt/grass/grass5/bin/r.water.outlet
> File not found: /opt/grass/grass5/bin/v.make.subj
> File not found: /opt/grass/grass5/bin/v.merge
Disabled due to bugs.
> File not found: /opt/grass/grass5/documents/html/d.leg.thin.html
> File not found: /opt/grass/grass5/documents/html/i.grey.scale.html
> File not found: /opt/grass/grass5/documents/projections_supported.html
> File not found: /opt/grass/grass5/documents/raster_complete.html
> File not found: /opt/grass/grass5/etc/bin/cmd/d.leg.thin
> File not found: /opt/grass/grass5/etc/bin/cmd/i.grey.scale
> File not found: /opt/grass/grass5/etc/bin/cmd/r.combine
> File not found: /opt/grass/grass5/etc/bin/cmd/r.resamp.rst
> File not found: /opt/grass/grass5/etc/bin/cmd/r.water.outlet
> File not found: /opt/grass/grass5/etc/bin/cmd/v.make.subj
> File not found: /opt/grass/grass5/etc/bin/cmd/v.merge
> File not found: /opt/grass/grass5/man/man1/d.leg.thin.1
> File not found: /opt/grass/grass5/man/man1/i.grey.scale.1
See above.
> File not found: /opt/grass/grass5/tcltkgrass/module/v.support_option=build
> File not found: /opt/grass/grass5/tcltkgrass/module/v.support_option=edit
The "=" has been changed to an underscore.
> File not found: /opt/grass/grass5/etc/bin/cmd/v.in.arc.pg
This is in $GISBASE/etc/bin/inter.
Glynn Clements <glynn.clements at virgin.net>
