[GRASSLIST:2970] Re: GRASS pre 3 on RedHat 7.2
Daniel Tourde
ted at foi.se
Wed Jan 23 06:40:11 EST 2002
Hej Markus,
> please send them to me (attachment), I'll put them into the CVS.
> Thanks a lot,
Here is what the .spec file produced as errors (remember I used the one
from pre2). It seems that some files have either changed place,
disappeared or have not build for me.
Could you please tell me what I am supposed to do?
Remove these files from the content of the rpms, move them or try to
determine why they never built.
Thanks in advance
Daniel
Requires: GRASS = 5.0.0pre3 ld-linux.so.2 libc.so.6 libdl.so.2 libm.so.6
libodbc.so.1 libpthread.so.0 libz.so.1 libc.so.6(_2.0)
libc.so.6(GLIBC_2.1) libc.so.6(GLIBC_2.1.3)
RPM build errors:
File not found: /opt/grass/grass5/bin/d.leg.thin
File not found: /opt/grass/grass5/bin/i.grey.scale
File not found: /opt/grass/grass5/bin/r.combine
File not found: /opt/grass/grass5/bin/r.resamp.rst
File not found: /opt/grass/grass5/bin/r.water.outlet
File not found: /opt/grass/grass5/bin/v.make.subj
File not found: /opt/grass/grass5/bin/v.merge
File not found: /opt/grass/grass5/documents/html/d.leg.thin.html
File not found: /opt/grass/grass5/documents/html/i.grey.scale.html
File not found:
/opt/grass/grass5/documents/projections_supported.html
File not found: /opt/grass/grass5/documents/raster_complete.html
File not found: /opt/grass/grass5/etc/bin/cmd/d.leg.thin
File not found: /opt/grass/grass5/etc/bin/cmd/i.grey.scale
File not found: /opt/grass/grass5/etc/bin/cmd/r.combine
File not found: /opt/grass/grass5/etc/bin/cmd/r.resamp.rst
File not found: /opt/grass/grass5/etc/bin/cmd/r.water.outlet
File not found: /opt/grass/grass5/etc/bin/cmd/v.make.subj
File not found: /opt/grass/grass5/etc/bin/cmd/v.merge
File not found: /opt/grass/grass5/man/man1/d.leg.thin.1
File not found: /opt/grass/grass5/man/man1/i.grey.scale.1
File not found:
/opt/grass/grass5/tcltkgrass/module/v.support_option=build
File not found:
/opt/grass/grass5/tcltkgrass/module/v.support_option=edit
Bad exit status from /var/tmp/rpm-tmp.68369 (%doc)
File not found: /opt/grass/grass5/etc/bin/cmd/v.in.arc.pg
Daniel TOURDE E-mail : daniel.tourde at foi.se
Tel : +46 (0)8-55 50 43 44
Cellular : +46 (0)70-849 93 40
FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden Fax : +46 (0)8-25 34 81
