[GRASSLIST:2968] Re: GRASS pre 3 on RedHat 7.2
Markus Neteler
neteler at itc.it
Wed Jan 23 03:40:32 EST 2002
On Wed, Jan 23, 2002 at 09:25:12AM +0100, Daniel Tourde wrote:
> Hello,
> Thanks for your answers. They solved my problem.
> > I ran into the same problems compiling pre3. I am running RH7.2 as
> > well...
> > I resolved it the same way that Andrea explains...but also ran into
> > several others that you will also have to include, or not include...they
> > are: dbm (found in /usr/include/gdbm) ; postgres (found in
> > /usr/include/pgsql) ; and fftw (which I did not include, if I remember
> > correctly.). The reason that I did not include the fftw is that I could
> > not find it on my computer. Any ideas where it might be, or might it be
> > hiding under a different name??
> > Hope this helps...
> I already knew for fftw and postgres (I had the problem with pre2....).
> Now it is compiling.
> I have slightly modified the .spec file. If someone is interested to
> build RPMs for his RedHat box, I can send it.
Daniel,
please send them to me (attachment), I'll put them into the CVS.
Thanks a lot,
Markus
